CMF_sikK11
» CMF MemberHey poeples my girl and i have decided we want more zip out of the micra, Now i have read a lot of the forums on this matter and have decided to use a t25 with a custom manifold and exhaurst,we also want to use a top mounted intercooler with a WRX STI scoop as we want the A/C left in working order. The problem is i cant make up my decision on the fuel management system i will need to run. Will the standard stuff work with a better fuel pump and a rising rate regulator or will i need something along the lines of a Apexi SAFC and injectors.
The only other thing i am worried about is the stock internals.Will they hold up with around 6psi car has done 160,000klms.
Also how much do second hand engines go for roughly.
Thanks guys i hope to be sharing more details with you soo
