Amp
K
kris_micra_si
Hi,
I installed My Sony CDX-2250 a while back and was wanting to put an Amp onto the system, however when it has come to im a litle confused and wonder how anybody else might have overcome this problem. the wiring to the front panel is fine, however when trying to get the positive battery feed to the battery from inside the dash seems impossible. i have taken off quite a few front panels etc, and still cannot find some sort of a way of manouvering a wire through from inside the car to the bonnet? any ideas?
There should be a black grommit under the bonnet, puul it back and feed the wire through there and feel about under the dash and grab it.
If that fails, fe it through the side of the wing.
Install
Thanks Guys for that, i found it and managed to get the wire hooked up. wondered how you guys would recommend earthing it. just drill the chassis? or is there any earth spots on them? cheers again.
kris
