adjust Supercharger
i only want to raise the pressure like 1.2 bar. If i remember correct baz had a boost controller in one of the pipes in the ufo valve
Yeah it actually bleeds of some air from the bypass valve and adds some turbo boost pressure to it, the s/c is still boosted the same
Lol just saw this, if you connect up the lines wrong the SC makes loads of boost! You definitely don't need to change the pulley ratios :)
