5v ignition module distributor signal wire nissan micra k11 1.0
Hello,
I've been trying to install an Ldperformance Launch control device on my 2000 nissan micra k11 distributor version (not coil on plug).
I need to install it between the 5 volt coil signal wire coming from the ecu to the distributor but i cant find which one it is. I've installed it between the Green/white wire on the distributor but it didn't work and when i measured the voltage it was giving 15volts and not 5 volts.
Does anyone know which wire from the ecu is the 5v signal to the ignition module wire?
Here are some pictures of the wire diagram of the launch control device.
