1999 Micra Brake Drum/Shoes
Hi
Do you need to remove the bearing nut to take off the rear brake drum?
If so what the correct procedure to tighten it back up?
no .... just jack the car up take the wheel off hit the drum with a hammer at 9 and 3 as if it was a clock you where looking at so it will knock the shoes and wheel cylinders in abit so you can get the drun off alot easier
