1995 micra k11 SLX need help adjusting clutch
CMF_95micrayep
Hi there, I got myself a 1995 Nissan micra k11 SLX and the car is in great condition but the clutch pedal sits further down than the brake pedal, I can put my foot under the pedal and pull it back to it's right spot but obviously someone adjusted it wrong previously. I have had a look in the hood and can see where the clutch cable is but I'm unsure on adjusting.
Any advice would be much appreciated because at the moment I only have a tiny bit of clutch.
CMF_niiCk
like under the dashboard..so where the pedals are themselves..
im pretty sure it applies to most cars..well my cars are the same.
get to the clutch pedel then theres a bolt which you can adjust for the height of the clutch pedal..theres one nut that is a locking nut, so loosen that first then tighten the bolt till youre happy with the height then tighten up the nut again..
CMF_niiCk
ahh right..i just fully read the whole thing lol..
dont worry about what i was telling you earlier..that was just adjust the pedal to a certain height:)
CMF_mycra
is the car running a HD cluth?... i have the same problem with mine but doesn't really bother me...i refer it sitting further down(less effort)
like frank said i'd be adjusting it from the gear box-side though not pedal
CMF_95micrayep
That was my plan originally is to adjust it under the battery but I was unsure on how to adjust it there. The clutch is all good but I'm only using a tiny bit of it which bothers me. There is a locking bolt and the thread itself is a nut thingy connected to the clutch cable.
