Hi all was just wondering if either of these set ups were better/easier to fit/run better as think my dads found a 100nx being broken and might get the brakes off it and sell my pulsar ones, dependent on results from this haha!
There are two types of 100NX brakes.
on 1.6L -> AD18V (and rear drum brakes), These are also found on normal Pulsars
on 2.0L -> AD22F (calipers both rear & front), These are also found on Pulsar GTi-R's
Both will fit,but both need washers to fit properly. If you are in the UK, you'll probably only find AD18V's, since there are hardly no SR20-powered GTI NX's
Good luck with the conversion!
Thanks a lot! The main area I was wondering about was the brake diameter because apparently the gti-r ones rub so wondered if the 100nx ones did too...
