1.0 lightened flywheels?
Is there such a thing and a lightened flywheel for a 1.0 as I despratly need a clutch and being a bit ana l I'd like to have a new flywheel aswel or a lightened one ?
Don't know if they are available but any good engineering company could drill some holes out of a flywheel, probably cheaper too, just agro.
.. 3.2 kg
I have a 180mm one? Would that fit. It is also a alloy lightweight
Why? Different grades of alloy? I can polish it to make it shiney just been sitting around for a while. So what is the 190mm and 180mm used for ? Different year boxes?
I'm not being funny if it reads that way. Genuine question as I've never used mine?
Brace urself, this is going to sound ****.Well it doesn't look very robust to start off, possibly too much removed... Also worryingly the set of three drilled removals don't look at all even and I just wouldn't trust it to not fall apart under power. I may be talking out my arse tbh, the good ole fashioned saying. If it don't look right, it probably ain't right. It looks dangerously attacked. Maybe franks opinion or someone's opinions may hold better weight. You watch its going to be someone's work and I hope I don't offend them. I suppose on a non turbo motor you might be alright. My opinion has no weight on fact or expertise. I just try to look at things realistically and with common sense.
O
paul,s looks like a preface 1.0 one to me ? and looks to be engineered ok from this distance, would clean up nice :)
chris,s looks the dogs :)
pink scales officer they's ligit,,,,,wait um on riky's blog,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
