here it is here, Fordy gave me these instructions and it worked
1, turn the ignition to on and off 5 times, then leave ignition off but key in barrel still
2, hazards should flash to show coding sequence started
3, hold black button and press red button 3 times
4, hazards should flash to indicate fob coded
5, do same as step 3, to second keyfob
6, hazards should flash to indicate fob coded
7, turn ignition on
8, hazards should flash to show coding sequence completed
9, test both key fobs
you might need to close all the doors and be inside it when doing it as sometimes it wont start the coding sequence,
also you might need to turn the ignition on and off 6 times, i cant remember if its 5 or 6 its a second nature to me so i just do it and not count lol
