curtis
Today i reconnected the ignition idle control system cable, which had been cut?!? :glance: not by me!
Why would someone want to cut this connection?....and yes it was cut, i'm 100% sure of it.
And another question....
If you put a air filter on instead of the standard air pan, what happens to the vacuum tube that is connected to the air pan.....would blocking this up with a screw be ok, or would this cause damage to the engine?
thanks in advance....
Curtis.
Curtis.
