I'm sure that there is a pretty extensive post by Antony some where. Do a search.
But in a nutshell, IIRC Renault are the only manufacturer who use a larger bore size than nissan so their wheels fit straight on. The mojority of other manufacturers whose wheels are 4x100 use a smaller centre bore which can lead to problems with the wheels not going on. Some VW wheels fit because the taper into their slightly smaller centre bore fits over the nissan spigot. Wheels with a smaller centre bore can be machined to fit, or spaced out past the nissan spigot (longer studs probably required). Look for wheels from Renault, VW, Vauxhall, Some Honda, Mazda, other Nissan models.
To check PCD measure from the inside edge of one stud hole, accross the centre to the outside edge of an opposite stud hole. If it measures 100mm they are the correct stud pattern. and the centre bore is your next worry. A cut down ruler will help.
