WANTED: SUBFRAMES
i cant find the number of the place i spoke to about it. but i simply made my own from the subframes of the original seats. (spare set)
quite easy reallysimply welded a bar across (due to the bolt holes on base of bucktet being narrower) then bolted the seats to the bar. making sure the bar you weld in is box secioted to give you the strength it needs :D
hope this helps slightly
i fitted some cobra seats in my k11, the front two holes were just about in the same place, just made em a bit bigger by drilling with a bigger drill but then welded two pieces of 8mm thick mild steel coming offf the back the correct distance apart, if you had the seats and subframes infront of you youd see what i mean
Just wondering if anyone could make me some or could sell me some that would just fit in the normal subframe place, so i dont have to bother with all that work..
