temperature gauge
My friend has a 98 micra and the temperature gauge goes straight to hot when you turn on the ignition.The temperature control switch has been changed but still has the same problem.Is there anything else we should be looking at.
sounds like a dead short rich, you will probably need to trace the signal wire back to see if its earthing/shorting out
