Hiya,
I've used the search facility to see if I can find an answer for this, but still not 100% sure, so thought I'd ask.
Took the car for an oil and filter change today, and when I got it back, the monkey behind the counter said I had a flat battery. I thought it a bit weird, because the car normally starts really well.
So...... I went out to try and start the beast.....wouldn't start. It's turned over, but wouldn't fire. Had to try three or four times, then it started up. Drove about 15 miles home, parked up, and tried again after 15 mins or so.....started no problem.
I guess a battery problem is ruled out, if it's turning over ok? From what I've read in other threads sounds like dizzy cap / rotor arm? Anything else I need to check? Plugs were changed about 6 months ago.....don't know how often they need doing?
Sorry for being such a girl. :blush:
Cheers.
Cheers.
