Spacro Pedals
M
micraisok
Brand new, still in packet. Accelerator, Brake and Clutch. comes with fastening bolts. bought from demon tweaks for, when p+p added, £20.
looking for £15 collected, or £17 posted
tse_adam said:
drilling required for these?:down:
Drilling is required for any metal pedals to be put on. For it to pass an MOT aswell and be legal there has to be a 4cm spacing (I think) between each pedal. Also if they havent got them, you might want to purchase a rubber backing for them so that it goes through the holes to grip the soles of your show.
If you don't, chances are the first time you try and drive with wet feet your heading straight for a tree.
they will fail MOT as the brake and clutch don't have non slip surfaces, they should have rubber protruding above the surface, However, Rally Design sell the rubber inserts for Pedals
