M maximus Jan 23, 2008 #1 Wanted rear wheel bearings and rear brake shoes for a W reg k11 Thanks Maximus.
Micra 110 Site Supporter Jan 23, 2008 #2 You're local Motor factors should have them in stock, if not they'll be able to get them pretty quick
curtis Ex. Club Member Jan 23, 2008 #3 http://www.buypartsby.co.uk/brake-p...v&Submit=Submit&txtmake=NISSAN&txtmodel=Micrahttp://www.buypartsby.co.uk
solarice Ex. Club Member Jan 23, 2008 #4 your rear wheel bearings arent going to be cheap...maybe easier and definatly cheaper to have a search in a scrapyard...
Micra 110 Site Supporter Jan 23, 2008 #5 Have a look at this site...http://www.nskf-bearings.com/index.htm ....there might be the Bearing/Hub you want or least if you get the part number it would make things easier, i'm presuming the Bearing is built in to the Hub?
