Hi everybody!
today i try to instal the sandwitch plate for the oil press sensor but there is a problem!
i don't have space to install it.. its to much larg and long..
someone can tellme any solution?
Hi everybody!
were you trying to fit an after market oil pressure sensor for some kind of oil dial, and there is not enough room in the space you are trying to fit it? or is it the gasket (sandwitch plate) that is too big? and in what way is it too big? does it push the oil pressure sensor out too far so that it hits something? or is it just the wrong gasket and it doesn't fit?
The only problem that you have is the casting on the block where the screw at your lower red arrow is - this will need to be filed back to allow the sandwich to tighten up properly.
With regards to the brace for the inlet manifold, just slacken/remove it, put your sandwich on and replace the brace.
Does this make sense - not sure what your 1st language is?
