CMF_lue_driver
» CMF Memberive seen somewherer that some models had a rev meter...
mine dosent...
how much would the conversion cost...?
...in total...
mine dosent...
...in total...
nz_aj WROTE:
"There are pictures posted in some threads about 1-2 weeks ago & others a few months ago.<BR>There are two different wiring loom versions, UK-Europe-Australia & Japan-NZ.<BR>All use the same electrical plugs but from all accounts there are some wires that may be connected differently.<BR>My K11 did not have the signal wire from the ECU in the loom between a plug close to the ECU & the plug into the back of the cluster, all others I've seen have had the wire.<BR>The cluster I obtained was from an automatic, so it had a PRND21 indicator on the speedo. I swapped the speedo from my non rev counter cluster into the rev counter cluster. <BR>Aside from this, it was plug & play.<BR><BR>I have no idea about the cost in Greece. In NZ, NZ$24 comes to mind from a pull it yourself wrecker.<BR>Typically it would take about about an hour to swap if you've never taken the instrument cluster out before. If I was racing against the clock, 5 minutes.<BR>There are at least 3 different versions of the dash board with variations on the location & number of screws that you have to take out to remove the cluster.<BR><BR>This information & some pictures & any other information from previous posts need putting in the articles section.
