J jowlemicra Mar 31, 2007 #1 hi i have a 1.0l micra is there a way to fit a rev counter to the engine
superls K10 Tuner Mar 31, 2007 #2 have yougot a rev counter in mind that you would like 2 use if you get a rev counter thet requires a switching negative (most) then you need a wire off of the blue wire on the coil (terminal nearest the front of the car, if it hasent been moved)
Arnold www.alanarnold.co.uk Moderator Site Supporter Mar 31, 2007 #3 Do a search fella, this has been covered a few times
