Hi,
Is it an easy job to replace the throttle body on a coilpack Micra?
From what I can see, the airbox obviously needs to come off first.
Then its 3 sensors that need unplugging from the throttle body - MAF, TPS, IACV.
And then two screws that hold the throttle body to the inlet manifold need removing.
And finally accelerator cable needs to be removed.
Then the throttle body should simply come off?
Am I missing anything?
