micra_k11 said:anyone able to help? do after market repreaters have three pins or two?
you won't need any other wiring. you should've got the new bulb and bulb holder with your new repeaters. take the old ones off and the wiring should clip off the old bulb holder- there is a little tab on the connector that you have to press in and pull the connector off. plug that on your new bulb holder, fasten it into the repeater and clip it into the wing.micra_k11 said:i didnt receive any other wiring...could this be what i need?
goldstar0011 said:There's a guide at http://www.mightmicra.co.uk
micra_k11 said:got a 2001 model, managed to get the original indicators off, but the part where the indicator connects to the wire is 2 pin, and the smoked out ones are 3 pin. and the wire seems to be stuck to the 2 pin part. any ideas? :down:
I cant get this either.goldstar0011 said:There's a guide at http://www.mightmicra.co.uk
rlees85 said:i bet mightymicra is for pre-facelift. the wiring is different on facelift.
just checked and the guide on mightymicra doesnt apply at all to facelifts.. sorry!
the reason why it doesnt is becuase facelifts dont have the plug under the wing, the bulb holder is wired staight into the circuit with no plugs in between.
the only way of sorting it cheaply is what i said in my post unless anyone else has any ideas!
