Pedals
Hey, just measured the pedals on mine and only problem looks like to me is the accelerator pedal of those sparco ones are gona sit a lot closer to your brake pedal as its 10mm wider roughly and I'm guessin the brake pedal is gona be slightly wider so if you got smallish feet should be okay without catchin brake pedal, mine are still standard but i wear skater trainers size 12 and only just stop touching it, drive barefooted now
aftermarket pedals can be a pain... remember that most of the screw in type means drilling through your pedals... the accelerator is going to be the problem as above has said...
I measured my pedals the other day: the clutch and brake pedals are 60x60cm and the accelerator pedal is 40x100cm. If these Sparco ones have the correct fittings so I can just alan key them on that'd be great. I guess I should check then how close the pedals will be set apart with these though as there's a legal minimum that the pedals have to be apart.
