original sticker removal - help
CMF_rowstar
Hey, i want to attempt to remove the original 'nissan MICRA' stickers off my front doors. there is also one long thin stipple patterned sticker that runs along each side. yuk! this will be a big job i think.
Can i also remove the long plastic panel protector that runs along the door?
any tips on how to get them off?
i know how to get badges off and clean off all the rubber residue, but original stickers on painted panels is another thing altogether i guess.
cheers!!
smidge
the panel protector if its colour coded will look better on
other stickers are usually removed using a solid plastic edge that won't scratch your clear coat, and a hair dryer or head gun
i find a small hair dryer puts just enough heat in to soften the glue without burning your hands off
smidge
yeah could work, i use wax and grease remover to get the last of the residue off... no particular reason only that it doesn't eat the paint as long as you make sure you get it all off afterwards
