How are the wheels held on, and what fitting are factory alloys taper or radius?
Thanks.
Thanks.
the wheels are usually held on with magic...
See my response below.
why ask? if you are planning to change the wheels you will see what holds them on.
Are you suggesting that i should start the job before knowing what i may need, or having bought the correct parts before hand? See my response below.
there are studs in the hub and the wheels are held on with wheel nuts.
Thanks, thats one of the useful peices of information I needed.
the PCD (bolt hole alignment) of the wheels are 4X100
Already knew that, thats why I didn't ask it.
the nuts are on a 14mm thread at a 1.25 pitch
Thanks, thats the other peice of information i wanted
the nuts are 21mm which is the same size as the tool that you should have in the back of the car for undoing them.
Ok, so perhaps I didn't make it clear I wanted the thread size, but i think the context I asked in regarding the pitch could have made that obvious. See below.
wheel rims above 15 inches in diameter can start to scuff the inner wheel arches.
Not something I asked in this thread, but could be useful in the future. Thanks. Although I'm pretty sure where it scuffs has got more to do with the offset of the wheels and the tyre size, that it has them being 15" diameter.
Bold used to show my response.
So why is the sarcasm needed? It just makes you come accross like you might be a complete ####.
I'm doing a bit of research so that when I do get round to changing the wheels, I have already got the equipment i need and know what i'm doing. Yes there are a number of ways i could find out this information, but I thought the easiest way was to ask people who will know the answers.
When my new wheels get here, i'll be able to identify what mounting seat they have, and thus what nuts i need, these might be nissan factory nuts suitable for alloy wheels, i might need to source them elsewhere. But at least I will know what thread diameter and pitch to order.
Thanks for the help you did give. Although I'm now wondering if I really want to be a member of this forum.
