Need help @ Topic "Rear wiring"
CMF_DevilBoy666
Must I need use the connector with the two cables or can the connector be unused?
I just wanted to make rear boxes to the other connector(four cables) without amplifier.
CMF_Greo
You could get some pin connectors with wires attached and slot them into the connection box. Or just cut it off as the 4 wires shoul just be for the left and right rear speakers
CMF_DevilBoy666
hm yes ok that i know.
But what must i do with the other connector, nothing(that would be good)?
Must I need use the connector with the >>two<< cables or can the connector be unused?
CMF_Rudy
all three of my micra's have rear speaker wires fitted by previous owners, none seem to have the rear plug u have. your car is a 98?? which we didnt get here, the looms are different from lx & sup.s & slx and from year to year. Yours is a left hand drive euro model which may have its own trim options. Are u sure they are speaker wires, if your car isnt a high spec micra it may not have the rear wires. Haynes wiring guide is based on 96 models with six speaker system, mine only had two in doors
CMF_DevilBoy666
@ Rudy tanks answer
the rear speaker wires not fitted by previous owners.
(um how do I tell) i think that ar standart wires from manufacturer.
for special equipment if the customer wanted the rear speake?
its a Micra K11e 03/1998 ~55hp
hm im not sure but i think that the Plug is for rear speaker, becorse i found a Plug behind my Radio (see on foto -> http://www.micra.com.au/images/community/forums/66039.jpg ) and there are 4 wires for rear speakers. That Plug can i put in to the Radio too.
first i have search the end of that Plug an have fond it at luggage space with the same wires(colors) (see on foto --> http://www.micra.com.au/images/community/forums/66040.jpg)
so I think it is for rear speaker. (i have only 2 front speaker too)
But i dont know what i must do with the other plug with 2 wires? :((
sorry for double threads
