Missing knob!!
Someone in the past broke the direction control knob off the heater and shoved loads of glue in the void. How do I get the dashboard off to repair/replace it? Ta. Klang.
ANYway, crap Double Entendres aside, is there a thread/tutorial on how to get to the heater controls/get the whole dashboard off? I have access to an angle grinder!
Iirc the facelift is very similar to the preface :) just remove the center console :) take out the stereo then above where the stereo slot is there's two screws and then there's two screw behind the ashtray take them out may also be two under neath not sure without looking :) and then pop that centre peice out and disconnect the cigarette lighter :) and its all good :) thatll reveal the controls and then its just 4 screws and some conector blocks :) may be wrong though if replace that console to be honest over repair and then you can use the angle grinder to cut up the old one :D x
