Midrage misfire
Hello, has anyone had delt with a misfire. My 1.0 micra will start fine, rev it and there is a misfire which then clears at higher revs. Wierd or what. It's drivable but unpleasent,i have resoldered the throttle body. The distributor cap,leads and plugs are in good nick and no fault codes are showing. any idea's
I had this on mine recently. Check the spark plug holes (don't know the technical word!) for moisture by revealing the spark plugs. If there is moisture around the spark plugs or on the distributor lead thing ( again don't know!) itself, dry them out using an air compressor. Then go for a spirited (or hard!) drive to clear out any crap from the exhaust! It might misfire at first but mine cleared up perfectly once I had done that. I have a coil pack 2002 1.0 S which had the same problem as you.
Hope it works for you!!
Jak
