H
Herr_spl1ff
Ok, it's started, I have the following items for sale, all from a K10, more to follow. If you want something specific, ask as I might have it!
1 pair brand new front lower wishbones: Never fitted, NOS from ebay Complete wishbones. Paid 35 quid, yours for 35 quid as still in packaging.
1 Magnex exhaust box: Originally a performance middle box, straight thru 3-4 inch bore, very loud, stainless. Welded to an original Micra back exhaust pipe so should fit straight on. May need a bracket welding but will confirm when I check. 20 quid to you
1 MA10 engines FREE TO A GOOD HOME!: Needs the head refitting. Was kept inside until recently when I ran out of space so could do with a strip down and clean. Roughly 100K on it.
1 four speed gearbox: Complete working unit from above engine, no problems. Ready to cure your gearbox gremlins (Arnold... ). Make me an offer...
1 pair headlights. Good condition, £15 each or £25 the pair
1 pair rear light clusters, cracked on the bottom lip, would be stuck in place when you masticked them back on so £5 each
More stuff than I can remember right now! I've broken 3 Micras for parts over the last 2 years and have most of the parts lying around so ask if you want something!
Based in Sheffield (home) or Hull (work) or in between if you're nice to me . Can sort postage for some stuff & maybe courier for others.
<<<<<<<<<<<<<<<<<<<<<< Update >>>>>>>>>>>>>>>>>>>>>>
Ok, some bits gone, cheers MatT, hope you got back ok!
Many bits still available including a full nearly new standard exhaust system, should fit any K10.
Assorted small bits, washer bottle, LS clocks, air pans, etc etc
Oh, email is here: the_viking_er1k at yahoo dot co dot uk
