Lambda sensor wiring metal support
Hi, Everyone. How do you separate the electrical socket piece from this metal support piece? It is the one that holds it off the hot valve cover and powers the lambda sensor. I'm afraid I will break it and I don't see how you get a screw driver into it to make it release. Do you just pull really hard? Photos provided. Many thanks. k11 Micra 1.0. Sprucing up the engine bay.
IIRC from removing mine for testing, it's just a quite tight friction fit. Give it a good wiggle while pulling and it should come off relatively easily.
