There are 3 screws if I'm not mistaken. 2 at the top and 1 behind the front bumper. Used 10mm socket to remove them. The 1 behind the bumper is very tricky and pain in the butt.. Either you take the bumper off (which is long process n MOST likely will brake the brackets if not careful) or remove the front grills and squeeze your hands in between the gaps to unscrew it.
I've done the both process.
Once done and lights changed, don't bother with the screw behind the front bumper just in case you need to open them lights again.
Hope that helps
