K11 Lower Arm front bushings
Just wondering if anyone is able to tell me the dimensions of the front, round bushings on the K11 Lower Arm? Specifically the polyurethane equivalent
Sent from my SM-G900F using Tapatalk
frank
i came across 2 different types, both circa 96 and both with same factory stampmarks/numbers on the wishbones
1 had a steel casing (27.5mm ?), and 1 had a tapered/stepped socket on the wishbone (27 + 30mm)
you have to bear in mind that that bush locates the wishbone in a fore and aft direction, and any movement towards the front or rear badly effects the tracking (i speak from experience :( )
