K10 pulling badly to the left. - Tracking?
It does it as soon as you let go of the wheel, pulls badly to the left even under braking.
Had similar problems with novas in the past but that was due to their crap callipers sticking.
Do micras suffer the same or will it just need tracking? tyres don't look to have worn unevenly either.
check tyre pressures first
how bad is badly? could be just sticking brake pad, misadjusted caliper etc..
how many degrees do you have to turn the steering wheel to get the car go straight?
does it get worse when braking?
bend axle or something like that would be worse..
Tyres pressures are fine as ive just put some air back in them, it pulls alot, if you let go of the wheel you can really feel it drifting towards the curb, doesnt pull violently though.
Its the same under braking, no better or worse. Could be a wishbone then, its only done 26,000 miles and im the 3rd owner, im guessing the first elderly owner probably hit a curb at some point then. Will get the tracking checked at some point and see whether its out at all.
