CMF_asdame
» CMF Memberhi. i recently brought a 1993 k11 slx manual. Has power windows & central locking but no PAS/ABS/AirCon.
now interestingly it was originally an automatic according to the reg and vin #.
but seems it was involved in a front ender judging by the replaced front member, engine mounts resting too far forwards, wrong gearbox mount cos only 2 bolts are fitted and a big gap on the 3rd hole (prob the original auto mount on a manual gearbox, cracked radiator fan frame.
so at one point this car was converted from an auto to a manual, which is odd considering the amount of work involved compared to just sourcing a replacement auto box & engine.
I've just stripped down the entire car to restore and found the gearbox neutral & reverse sensors not plugged in cos the automatic wiring loom can't reach, and that the original wiring loom for the automatic with the e-cvt control box was still there.
I'll be replacing the loom between the ecu and the engine bay with a manual version in order to be able to connect the neutral & reverse plugs but the rest of the internal wiring loom i noticed theres the old kickdown switch wiring, a lead to the automatic gearbox lever (prob for sensing park?).
Now my question is,
is the wiring loom inside the cabin of an auto the same as a manual version, whereby i could just replace the ecu-engine loom with a manual version and throw out the e-cvt box?
or would you recommend replacing the entire wiring (engine bay - ecu - interior) with one from a proper manual micra?
could it be that nissan just makes the interior wiring loom the same for both manual & auto micras and simply tapes up the connectors that are not used?
Now my question is,
