CMF_jdc5r » CMF Member Australia Member since: Posts: Dec 27, 2006 #1 Any way of removing the glove box fellow members? I checked around but didn't want to nudge stuff i am not meant to nudge. Thanks in advance
CMF_Yom » CMF Member Brisbane, QLD, Australia Member since: Posts: Dec 28, 2006 #2 Its easy. Keep it closed and locate the two pull pins down the bottom of the glovebox near where you'd expect it to hinge. Then unlatch the glove box and simply pull it from its position. It should come out with a bit of manouvering.
CMF_jdc5r » CMF Member Australia Member since: Posts: Dec 28, 2006 #3 Thank you i will give it a try.
