I have a Micra rally car and have recently bought a Lamp pod for night rallys. I then went on to convert the lamps to HID's.... This is where it got a bit confusing.... I researched HID's and started to understand what they meant...
The H number (H1, H4 etc) was a fitment suggestion
The W was the wattage which needed to be the right wattage for the ballast
the K number was the colour (5000k - white)
Anyway i ended up buying H4 35w 5000k Bulbs single beam
When they turned up they had aglare shield fitted!!
Does this mean i bought the wrong type of bulbs or do i just remove the glare shield? if so will these then be the bright or do i just need different bulbs ???
CONFUSED.COM
CONFUSED.COM
