D
Deleted member 29304
Hi All, I have been trying to remove the front bumper but have trouble with the removal of the front head light connection plugs, for some reason I'm unsure how to pull the plugs off the headlight bulbs as they appear to have some sort of metal catch built into the plastic connected to the bulbs & it won't release properly (please note I do not have the manual for this car only the Haynes manual).
I have notice that at one point in it's life My K11 had an accident & the passenger side front headlight appears to be lower than it should be as when the bonnet is closed you can slip in your fingers around the H/L, Is there a spacer below the H/Light to bring the unit to inline with the other headlight.
Yours Peter0003
Yours Peter0003
