hi guys i wounder if you can help me. i run a k11 on a M reg rally car in the f1000 championship and for the last few rallys it has had an intermittent fault. when it goes around fast left had bends it will not rev fully but if you dip your clutch , snatch another gear it generally clears itself. i have changed several throttle body's two distributors , plug leads and finally he ecu all do not seam to clear the fault. any suggestions.
