S
sussexpellett
Daughter (at uni) ran her tank near to dry, now has intermittant loss of power. Changed fuel filter. Still same problem.
I'm thinking debris in fuel line as most likely, vent blockage, leaky air hose or bad electrical connection on a sensor, as other possibilities.
She could take out fuel pump, look for crud, blow down hoses and spray WD40on connector blocks (which is more than most dance students would) but how do you rate her chances of cure?
If it's low, can you recommend a cheap(ish) mechanic in Guildford?
If you think you know the problem/cure, your right and it's not too expensive, there's free drink in it for you.
If it's high, she'll get her hands dirty.
(93 K11 1.0 manual)
Chris
(89 K10 Pao!)
(93 K11 1.0 manual)
Chris
(89 K10 Pao!)
