micra racer Mar 24, 2014 #1 How are you guys getting your lenses off to spray the inside black I cant seem to get mine off
MicrAde Mar 24, 2014 #2 Few minutes in the oven on a low heat and then (very carefully) prise apart with a screwdriver Sent from my HTC One S using Tapatalk 4
MicrAde Mar 24, 2014 #4 I would guess so, going steady of course, the heat is to soften the glue that holds the light together Sent from my HTC One S using Tapatalk 4
skymera Brutal Honesty Mar 24, 2014 #5 MicrAde said: Few minutes in the oven on a low heat and then (very carefully) prise apart with a screwdriver Sent from my HTC One S using Tapatalk 4 Click to expand... Pfft, I did 100c for 5 minutes with the plastic and bulbs still in
Chris Huzzey Mar 24, 2014 #6 skymera said: Pfft, I did 100c for 5 minutes with the plastic and bulbs still in Click to expand... you mean mine?
Magpie42 Actual Magpie. Mar 24, 2014 #8 Do they need to be seasoned before putting in the oven? Sent from the Magpie's magical nest using Tapatalk
Wagoneer Mar 26, 2014 #9 The obvious advantage in using the oven method is even heating. Is that 100 regular or fan?
