CMF_jay22 » CMF Member melbourne, vic, Australia Member since: Posts: Jul 6, 2007 #1 does the k11 have the sensors for water temp, oil temp-pressure, or do you have to get them if you want to put in guages? if so where can you get them?? cheers
CMF_evade » CMF Member Melbourne, Victoria, Australia Member since: Posts: Jul 6, 2007 #2 You typically get the sensors with the gauges. What you need is a an oil sandwich plate for the oil temp/pressure..goes between your block and oil filter..you screw the sensors into it. <img src="http://www.racerpartswholesale.com/images/sp1t.jpg"> and a inline radiator hose adapter for water temp.. <img src="http://www.jazzproparts.com/photos/GS-AW07-B-2T.jpg"> you need to make sure the holes in the adapters are the right thread size to match the sensors...also the size of the adapters suits the micra
