mickey&me
Site Supporter
(1) Steering Wheel, commonly used on Micra's and Almera's alike with Airbag sensors and ancillaries attached
Taken from an Almera 1.4 1999, very good condition cleaned up very well and all parts working as they should before removal
Here's a pic
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_155449.jpg
£20 pick up OR £20 + £10 delivery to UK (will confirm later)
(2) Micra/March Dark Headlights with a pinhole in one of the headlights
Bought some time ago on here i think, installed them once but didn't like the look (doesn't look too good on a red car but a black micra it would look awesome imo)
I think its the right hand headlight has a small hole in it, i bought it like this, seems as tho the previous owner put some HID's in it and burned a hole there (i am only assuming)
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_163034.jpg
£30 pick up OR £30 + £12 delivery in UK (will confirm later)
(3) Super S NON - NATS ECU
Taken from my old Super S which rusted and i broke, Works absolutely fine no problems at all, even swopped it with my current Super S and had not problems at all with it.
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_155514.jpg
£25 PICK UP ONLY OR ADD £10 postage
(4) Glovebox, ignition leads and speedo cover
Spares, not needed
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_155548.jpg
Ignition leads were bought from a local motor factor but are a little longer than the original leads but work fine. £7 pick OR £7 + £3 for delivery in UK (will confirm later)
Glovebox £3 OR £3 + £5 delivery in UK (will confirm later)
Speedo cover £FREE pick up ONLY
(5) Micra Rocker Cover spark plug oil seals (2 x sets available)
These are the rocker cover oil seals for the spark plug holes....
I had a major problem with oil leaking within the spak plug tubes, so after extensive research I found that the oil seals on the underside of the rocker cover can be replaced with new ones, I ordered 3 sets, I am currently using one set on my Micra Super S for a year now and no leaks!
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_160113.jpg
One set has the original Nissan packaging and part numbers = £10 pick up OR £10 + £2 Delivery in UK
2nd set are opened = £7 pick up OR £7 + £2 Delivery in UK
(6) Micra Seat belts sets
These are taken from various Super S's I have owned and broken, all seats are for at leastfor one car and maybe another one in there too
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_161635.jpg
Take the lot for £10 PICK UP ONLY
(7) Micra POV spec side mirrors in black
Has a few scratches but would be good after a good coat of paint and lacquer
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_161850.jpg
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_161904.jpg
£7 PIck up OR £7 + £5 delivery in UK (will confirm later)
(8) Micra interior side plate covers painted in black
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_162002.jpg
£2 PIck up OR £2 + £3 delivery in UK (will confirm later)
(9) Micra 1.0 Fuel rail with fuel pressure regulator attached
Taken from a 1996 1.0 Shape, worked fine before removal
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_162547.jpg
£5 PIck up OR £5 + £5 delivery in UK (will confirm later)
(10) Micra Drivers and Passenger side Front windows
Been stored in the garage safely for a couple of years, cleaned a few and they are in good nick.
NO pics yet - available on request
£10 EACH PICK UP ONLY PLEASE
(11) Micra Super S Rear pop out windows and fixings
Taken this off my last Super S which rusted, all but a tiny few fixtures are missing, enough to be able to fit to the car, should be able to find the missing fasteners from the junk yard from another micra
http://i202.photobucket.com/albums/aa61/Micraholic/Mobile%20Uploads/20150808_170507.jpg
£20 EACH PICK UP ONLY PLEASE
If you would like to come to pick up any of these, I am located in Wolverhampton which is 5-10 mins drive M6 J10.
PM me if interested
Ash
Here's a pic
Spares, not needed
PM me if interested
Ash
