Electric Windows ------------
Ok for you experts out there ..... i recently got myself electric windows with loom, side panels, buttons e.t.c... my car is a 1995 (M) reg 1.0L... now will this kit connect up to the loom to power the windows? cos when i had a look today with alot of trouble trying to poke my fingers around in the hole where the speaker loom gooes, i can only pull out and see the speaker plug but no other, no space to to fit my hand nearer to poke around for any more plugs for the electric windows.... is it there but hidden or no plug at all?
J
i aint to sure but check if the fuses or relays are in your wiring loom like the engine bay fuse relay box maybe
Cheers mate, as an ex auto electrician ill have to wire it up my way, ive done a mock wire up in my garden shed and all works.. just need to fit a 12v circuit breaker for the elec windows to stop the motor from running when fuuly up causing a blown motor, i may also need to get a spare passenger and driver side switches.
J
