Distributor rotor screw size
Hi,
I'm trying do diagnose an occasional rough-running issue with my Micra.
I bought it broken and fixed it with a new RSB-53 module. It just popped into my mind that the screw used to hold on the rotor was not the correct one and it might cause the rotor to be loose.
Could anyone measure the screw and associated washers etc. so I could count that issue out?
Thanks in advance,
Coffee.
Update: F-ed around and found out.
A M3 screw, 8mm length, with captive spring washer. Found loads in a bin at work. Gave it a drop of blue threadlocker for security.
Farnell link here. Or pillage your nearest frequency converter ;)
