DIG-S belt squezzing
Hi
I have changed the belts two times recently both belts with Gates belts.
I have squezzing when cold and after a couple of minutes in idle.
Tensioners should be fine.
What else could i check?
KR JCT
Are you sure the tensioners are fine..... have you tested them?
I had a garage initially swap out the belts, but a few months later the squeal came back followed by some rattle can/clacking type noise when cold and in the end both a main serpentine belt and super charger tensioners were replaced. The first garage missed that the tensioners were gone, or they were just about to go.
I have a thread with some videos on here somewhere.
