cvt transmission
CMF_helkelmit
hey everyone, just wondering if anyone can help me,i have a little 95 micra which i dearly love its been a fantastic car as micras are but iv got a problem with my transmission, it seems to be stuck in a gear which ive been told is limp mode, no one seems to be able to find the problem, one mechanic seems to think its something electrical in the tranny or the computer im just wondering if anyone else has had a similar problem any advice would be very appreciated. thanks
CMF_micrabits.co.uk
If the CVT light stays on try getting the fault code following the link above.
If the car seems stuck in gear, won't reverse etc. its probably the baulk ring jammed. We had a similar one and faced with the high prices of a replacement we had a go ourselves!
Take the gearbox out and take the inside casing (side that bolts to the engine) off.
On the end of the first motion shaft there is a brass baulk ring. You will probably find it stuck on. We used a plain screwdriver to pry them apart, put everything back together, tried it on the bench and it seemed to work.
When we refitted the box it all worked fine!
