Hello
I was hoping to get some help from some experts out there. I've been having issues with my K11 1.4 2000 micra, the car will run but will occasionally have big power dips and a couple of times stall. I think it is the Cam sensor so I've been at it with a multi meter and got some readings but I'm not sure if these are normal or not.
Negative to positive give an unsteady 4.6V and negative to the switching position is between 9.65V and 9.75V
I don't have access to a diagnoses tool and the engine light is on.
Is this the correct voltage readings for this car.
And thanks in advance.
