CMF_eM
» CMF MemberI'm just posting this for a friend. Please don't PM me about it. If you need more info contact [email protected]
4 Ohm Stereo Power
2 Ohm Stereo Power
4 Ohm Bridged Power
Frequency Response
Signal/Noise Ratio
Damping Factor
Minimum THD
Channel Separation
Input Voltage
Dimensions 4 x 75 Watts
4 x 150 Watts
2 x 300 Watts
10Hz - 40KHz
>100dB
> 200 @ 100 Hz
<0.044%
>65dB
150mV - 8 Volt
15†x 10.75†x 2.4†(LxWxH)
Want $350 NEG
Payed 750 for it, its in the box never used. It comes with everything. Even the allen keys and mounting screws.
please contact dan [email protected] for more info or pictures
4 Ohm Stereo Power
2 Ohm Stereo Power
4 Ohm Bridged Power
Frequency Response
Signal/Noise Ratio
Damping Factor
Minimum THD
Channel Separation
Input Voltage
4 x 150 Watts
2 x 300 Watts
10Hz - 40KHz
>100dB
> 200 @ 100 Hz
<0.044%
>65dB
150mV - 8 Volt
Want $350 NEG
