Dragonmaster_uk K12 NUTTER Feb 3, 2009 #1 as above really anyone got any tips on what to use to cut it with as i`m not sure what to use and don`t fancy attacking it with a hacksaw
superls K10 Tuner Feb 3, 2009 #2 good wire cutters depending on thickness, or tin snips, failing that id its only thin a good pair of scissors will do it.
joesouthgate Super Moderator Moderator Club Member Feb 4, 2009 #4 I used wire cutters, but its so soft you can do it with scissors.
Stani1029 Club Member Feb 4, 2009 #6 you shouldnt need anything, just bend it along the line you want and it will be more tidy than cutting it! trust me it works
joesouthgate Super Moderator Moderator Club Member Feb 4, 2009 #7 Stani1029 said: you shouldnt need anything, just bend it along the line you want and it will be more tidy than cutting it! trust me it works Click to expand... err my sheet of mesh was 4 times the size of my grille I wanted to mesh....so i don't think that would work!
chipedwood Ex. Club Member Feb 4, 2009 #8 I just used an old pair of scissors, the cut was quite neat too. It's easy enough to do just take your time and it will be nice and neat
squarepants Ex. Club Member Feb 4, 2009 #9 wire cutters..tired small sissocrs and broke them :S should be ok with a bigger pair though
