Bee r rev limiter help crankshaft and camshaft sensor pins on ecu
Camshaft sensor should be pins 30 and 22 connected together, white wire. Voltage feed from pin 48, blue wire. I don't think there's a separate crankshaft position sensor, that is handled by the camshaft sensor as well.
Pro tip, google "k11 micra service manual pdf" to find the Nissan service manual with wiring diagrams etc.
There's a green and yellow that need to be hooked would they just both go to each of the wires for the crankshaft sensor, much appreciated for the help by the way!
