Alarm fitting (Rclick)
Bought a rclick alarm and fitted it at the weekend on my girlfriend's Micra Vibe 1997. All seems to work ok, apart from when the drivers door is opened, it sets of the indicaters. Anyone had a similar problem? Reading through the manual it should do this when the doors are not closed properly, but they are. Strange!!!!!. I have connected the door switch wire from the alarm to the red and white wire behind the drivers side kick panel.
OK, when fitting alarms, which wire have you used for the door open which would set of the alarm. In the drivers door switch there are 3.
Anyone??
